Infinite horizon
I was checking this post http://archicad-talk.graphisoft.com/viewtopic.php?p=69559&highlight=horizont#69559 and found the tip "TIP: To avoid square horizon place your model on the big round slab - it will fake infinitive horizon nicely."
But there is now practical example of it...can someone demonstrate?
2 Replies 2
It's just a technique to trick the eye in to thinking it is an infinite view. All it does is visually remove the corners that you can get with a rectangular slab that will spoil this effect.
Does that explain it clearly enough?
Better would have been impossible.
Many thanks.
