Let me just say that this is a really great forum, the best I have ever seen for these kind of things. So....
Richard - I am definately rendering in lightworks, I have checked the materials for the window and the glass-clear is definately loaded as a material, I'm not sure exactly where to set the transparency of the window i will look through the options more and see what i can find, thank you for the suggestion and idea.
Dwight - where can i buy the book?
lousy to best? Are you refering to the "Method" under the light works effects pull down in photorendering settings?
All glass materials are identical in each window that is in this rendering.as for the light cone solid I'm still not sure what the deal is because I change positioning and the light cone comes out clean.
The background of the rendering I have not changed just the positioning so you can see that the options you recommended were the initial setup for the rendering.
