‎2003-11-04
05:32 AM
‎2023-05-11
02:40 PM
Noemi Balogh
‎2003-11-05 12:38 AM
‎2003-11-06 11:44 PM
lsid wrote:The brightener is a second light source (a point source) in the same lamp, it is a way to get a more general illumination from a spot lamp source. Often the brightener, which is invisible, is placed below a ceiling lamp to give a wash of light back up onto the ceiling. In Art.lantis you would use global illumination instead.
Strip lamp 70- what is the difference between brightener and intensity?
‎2003-11-07 12:46 AM
Bill wrote:
Isid
The direction of the lamp is controlled by GDL so you can edit the angle if you have to. As Miguel says ArchiCAD does not do a fluorescent lamp shape.
Usually when I use ArchiCAD lamps I try to get one lamp working and then copy it around. Also turn off anti-aliasing and reduce the rendered image size to speed up the rendering while previewing the light levels.
I hope this is of some help!
regards
‎2003-11-07 11:35 AM
‎2003-11-07 03:53 PM
lsid wrote:For this sort of question, Google is also a very good place to start. I've checked - and you can even get away with the 'I feel lucky' button for this one
....what is the anti-liasing? what does it do to the rendering?
‎2003-11-09 09:09 PM
...what is the anti-liasing? what does it do to the rendering?In simple terms anti-aliasing is a computer method of smoothing the jagged edges between the pixels that form a rendered image, it does this by calculating an 'average' colour for each pixel. Calculating this 'average' takes at least 4x the time to figure out for each pixel (high levels of anti-aliasing can be 9-16x). As a result renderings are much slower with anti-aliasing (but look so much better!)
‎2003-11-10 12:13 AM
‎2003-11-10 12:28 AM
Dwight wrote:smoorher
Anti-liasing is where diplomats have had a spat.
Dwight says, Anti-aliasing reduces the differences between pixel values to make edges smoorher.
‎2003-11-10 01:03 AM
