Visualization
Lightworks Bugs:
1. The camera setting is being ignored from time to time.
I am working in rendering a small mall. Lots of stucco set as plan mat element with casting.
Sun 100%, Ambient 80%, Camera 33% and a sky object at 80%
Stucco material: Color plain, Reflectance Matte diffuse .7, casting on, transparency none, texture none, pipeline none.
Form time to time I get (2) different result one darker one OK. When darker the camera fails to act and needs a small adjustment let sat from 33 to 32 than it works again.
2. From time to time the same I have a similar problem with the Sun object. Yesterday I have made a rendering wit it a 51% same setting as described today for the same result I need it at 80%
3. Why is the cast shadow not darker then the carried one as it is in nature. I cannot rectify this no mater what.
Djordje
I would switch the Camera light off.
The lower image looks more natural to me.
To quote Dwight, think about it as a photographer would.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I listed (3) problems??? you misunderstood one...
You missed my problem, the software acts erratically, here is light here is dark
In any event the lower image is much to dark, the real image should be as the top one but at the same setting yo get the two different results, this is un acceptable.
The the cast shadow should be darker bur it is not. In for Z the same Lightwork generates correct shadow intensities.
