‎2005-10-17
04:29 PM
‎2023-05-11
12:35 PM
Noemi Balogh
‎2005-10-18 06:35 AM
pablozar wrote:You are running out of memory. Try decreasing the image size.
Lightworks stop rendering (doesnt' begin instead). Progress bar reachs 40% and the end-rendering beep sounds but there's nothing to see, only the background picture. If I change the view angle or viewpoint height, sometimes it works and sometimes doesn't. Do someone know what could it be ?, this happens at home and office computers, both with same WinXP OS but different graphic cards.
‎2005-11-16 08:45 AM
‎2005-11-16 09:28 AM
kimfromzim wrote:Just to exclude the obvious:
No - it's something else - A different kind of 'Bug'!!!
‎2005-11-16 10:06 AM
‎2005-11-16 11:01 AM
Dwight wrote:Thanks Dwight. I tried that (on your suggestion) and it rendered that object (black, because no lamps were selected). So - I then tried the whole scene again and only the background rendered, once again.
Pick one element to render from the scene. This jogs it somehow....
‎2005-11-16 11:07 AM
‎2005-11-16 11:11 AM
‎2005-11-16 11:13 AM
‎2005-11-16 11:16 AM
