Maintain Window Transparency with Plant Materials
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-10-05
03:57 AM
‎2023-05-11
11:45 AM
Noemi Balogh
‎2014-10-05
03:57 AM
Any suggestions are appreciated....
15 REPLIES 15
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-13 11:19 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-14 12:26 AM
‎2017-09-14
12:26 AM
UPDATE:
Lowering the Ray Depth to 3 fixed the problem with the windows, but then introduced a new problem because some trees now render black.
ArchiCAD 27 (5003 USA Full), M3 Max MacBook Pro, 96 GB RAM, MacOS 14.5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-14 11:25 AM
‎2017-09-14
11:25 AM
Ray depth is about how many layers of transparancy you want to pass through. 3 is the bare minium, as anything with a thickness and transparant material has already two layers. If you have some overlapping trees, ramp up the number accordingly. 200 and 500 values are overkill. For most of my exterior renders I am fine with setting reflection and ray depth around 12. I keep treshold at 0, as this just makes reflections look better for only a slight increase in render times ussually.
I do not use any of the billboard objects, though. I either use 3d objects or the cutout contour objects. The problem is with the alpha channel / mask of those trees. It is just a rectangular picture with a transparant background, but you are still getting bits of the rectangle showing up / messing with things.
I seem to recall this was better or worse with either using physical renderer or not using it.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-14 11:31 AM
‎2017-09-14
11:31 AM
Just did a test render with some of those billboard trees, I can't say I am noticing any artifacts other than your typical poor/ugly masking of the picture where you notice white edges.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-14 05:18 PM
‎2017-09-14
05:18 PM
Thanks Erwin! Yes, you are correct, bumping up the Ray Depth will fix the problem with the transparent trees, but it causes the problem with the windows. Normally use a higher ray depth, but because of the window problem I don't know what to do.
What are the cutout contour objects that you were mentioning? The object shown in the rendering is Deciduous Trees 20.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-09-15 08:48 AM
‎2017-09-15
08:48 AM
The 3D contour people. There are no trees there.
Not sure what the problem with the windows is, but higher depth should only make them look more like they should.
If you find it too dark, try putting a general light set to infinite strength inside the building. Don't forget to turn on the light setting in cinerender when using that.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
