Maxwell Render Problem
The render could not carried on with following notes.
"Object _A2D82EED-8F11-4AE6-9FFC-23A36D565080 is not an emitter but it has triangles with emitter material. Data proprocess failed. Render cannot continue."
Any Help?!!
2 Replies 2
TMA_80
This object may have multiple material on it and Maxwell don't like that too much apprently , try to give it a single material or replace this object...
I remember having this kind of message with earlier plugins of Sketchup and 3dmax when emitter material was applied inside a group...
with some googling you could also find this
http://blenderartists.org/forum/showthread.php?230811-Exporter-addon-for-Maxwell-Render/page10
good luck
AC12_27 |Win11_64bit|
good luck
Thank you!
