2004-04-22
12:10 AM
2023-05-26
03:03 PM
Rubia Torres
2004-04-22 12:24 AM
2004-04-22 12:40 AM
Link wrote:Is this the same as opening a New & Reset, go to Attribute Manager and appending ALL to a new attribute file (att). and saving the att file as New&Reset81.att. ? Or does having the pln come in handy in other instances?
I actually keep a New & Reset pln file saved away solely for this purpose.
2004-04-22 12:59 AM
Link wrote:This is a bit cleaner than I had been doing it. You are an expert!
Check out this tip for switching out materials:
http://archicad-talk.graphisoft.com/viewtopic.php?t=1804
2004-04-22 01:03 AM
2004-04-22 01:15 AM
2004-04-22 01:33 AM
Sorry I did not mean to overwrite all in my template. I was talking about creating a attribute "reference" att file (like your "reference New& Reset pln) for purposes on appending from.Yeah - I get ya! Saving an aat file from a New & Reset needs Overwriting, not Appending.
So I quess my question is, is having a att file for copying around and testing the same as having a pln?Yes - it's even a little smaller than a pln.
I think though in Step Seven that you meant to say "Select the original Material ArchiLink 1" not 2.You're right
And Yes, having a copy of the pdf would be nice, if you do not mind.
2004-04-22 08:40 PM
2004-04-22 09:07 PM
