‎2007-03-16
11:27 AM
‎2023-05-11
12:27 PM
Noemi Balogh
‎2007-03-16 05:26 PM
‎2007-03-16 05:38 PM
‎2007-03-16 06:07 PM
‎2007-03-16 06:10 PM
‎2007-03-16 06:18 PM
‎2007-03-20 06:14 PM
Ingrid wrote:Try to save the block as 3ds from AutoCAD (wblock, open the DWG so created, save as 3ds) and then import into Archicad. Should work ...
Thank you so much for replying, Im quite frustrated at the moment:-(
I've attached a pdf with screenshots from 3d mode and Lightworks rendering of the bar. The bar is drawn in Rhinoceros and saved in Autocad (3dmode) as a block. My colleuge thinks it might be the parts made with mesh that is missing? Does that make sense?
Since it is saved as ablock, I cant understand how some parts can just dissapear...
If you want I can send you the dwg file as well?
Thank you so much again.
Ingrid
