Movie
How can I control the speed of the movie.
I make movie with 10 cameras. I want the movie to go slowly
Please help?!?
8 Replies 8
increase the number of in-between frames in the fly thru settings dialogue
bill
Thanks!
I have one more question
How can I control the smoothnes of movie.
In my case movie goes frame by frame.
Help
not quite sure what you mean by smoothness of movie but look at the following...
with a camera selected open up it's tool settings - there's a button for smooth path at camera
in the tool settings there's a path... button - open it up and make sure the path is set to bezier. you can also adjust number of in-between frames here
with a camera selected and the camera tool selected you can adjust the bezier control points of the path to fine tune it's curvature
bill
You also need to set the "frames per second" higher to stop frame by frame effect, 24 is pretty smooth and about what TV uses I think. Bear in mind this will effect movie length too, so you may also have to increase number of frames between camera. It all means more render time!
stefan
24 frames per second for Cinema
25 frames per second for PAL TV (used in Europe)
30 frames per second for NTSC TV (used in States)
From about 15 frames per second it's starting to look smooth, depending on how much movement is seen in the scene.
Archicad-user since 1998
my Archicad Book
another tip
always render fly thrus as individual, uncompressed frames and put them together later (with e.g. graphic converter)
gives flexibility of final output without having to re-render the whole sequence
bill
Link
Hi Stefan
I'd just like to clarify this - is it not best to use 29.97 frames per second for NTSC? I thought that was the magical number because it matched the frequency?
Cheers mate - hope all is well.
Link.
stefan
Hi Stefan
Link.
Well, it probably is, but only if your software has this option... (sorry, but without NTSC and without an actual television, it's pretty hard to test. I only have my PC to watch video, so I don't even see of the field order and colour space is correct when making a video...).
my Archicad Book
