‎2005-11-23
05:18 PM
‎2025-01-29
03:31 PM
Molinda Prey
‎2005-11-23 05:48 PM
howard wrote:ArchiCAD has the Lightworks engine (as well as a basic Phong engine) for rendering but unfortunately without radiosity. For that you still need to export to Cinema4D, 3DS Max or such.
I have acouple question id you don't mind me asking..
your renderings are done in Archicad and is it rendered in 3dsmax or another third party application or is it all rendered in archicad.?
Archicad has Radiosity feature when rendering ?
Can models created in 3dsmax be imported into archicad or vise vera ?3DS import and export are both supported (the former by an add-on). There are limitations due to the differences in the programs. 3DS is just a modeling/rendering format whereas ArchiCAD is a building modeler (3D is only part of what it does). So you will typically get better results from exporting than importing. I have had excellent result exporting 3DS to Cinema4D, but I believe there is now an add-on that exports directly to it.
Also wanted to know if any of you guys now if there's a dvd or cd training module out there that i may purchase to learn it..?I have been hearing good things about the Virtual Tutor disk for AC9. (I'll have to take a look at it myself some time.) You should be able to get it from your dealer.
‎2005-11-23 05:51 PM
‎2005-11-23 06:21 PM
howard wrote:In my case:
