Visualization
Object textures
Is it possible to align textures on objects, like on the example? Document -> creative immaging -> align 3d texture -> set origin / set direction, does not work.
https://photos.app.goo.gl/S7hbydLiMyGygAzu6
Have a nice day
1 REPLY 1
This would be possible only if the GDL Object is written in a way to enable that. I think these Objects are not written like that so it is not possible to modify the texture direction.
In such a case I would probably place a very thin (1 mm or thinner) slab or morph on top of the counter which would have a single texture.
