Outdoor rendering all black?
I tried to use outdoor white fast render but model become all black.
Did I do something wrong?
David Maudlin
Marut:
Check the Sun Settings. Check the Detailed Settings box, then go to Environment > Physical Sky > Time and Location and check these settings (Use ArchiCAD's Sun Position or correct the Day and Time and Location).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi, I just want to say that I ran into the same problem using the "outdoor white model fast (physical)" default setting, is easy to fix, just have to use the solution David said, just by selecting use Archicad Sun position, but I think it will be good if Graphisoft is aware of this.
