2010-07-05
		07:55 PM
		2023-05-11
		03:53 PM
			Noemi Balogh
2010-07-06 03:33 PM
2010-07-06 03:34 PM
laszlonagy wrote:I have only used black lines though, this what I don't understand. I also don't understand how by opening the same PDF in Illustrator, then saving it as PDF, makes the lines appear ' full' black...
What you can do in ArchiCAD is define a Pen Set that has only black and white pens. Apply that Pen Set to your Drawings and save that as PDF.
That should be black and white even if saved as greyscale.
2010-07-06 04:15 PM
2010-07-06 09:47 PM
2010-07-06 10:01 PM
Erich wrote:Nope, it's definitely a black pen colour. The files is a .pla (archive) and the elevations (which have the issues) are unlinked, not that it should make a difference?
NStocks,
You are certain that your pens are really black and not just something close? If you edit the pen color in RGB the RED GREEN and BLACK sliders are all 0 not just near 0?
Another possible option is to check the Black and White check box in the print dialog.
(sorry I can't speak the the illustrator issue.)
2010-07-07 08:24 AM
NStocks wrote:Yes, with Black and White, all colours are converted into either black or white based on their darkness. It may be that all colors are converted to black except completely white colors.
Please could you tell me the difference between black and white export and greyscale? Does B&W make all dark lines black whereas greyscale will make them into different shades of grey?
Thank You
