2007-01-30
10:06 PM
2023-05-11
01:28 PM
Noemi Balogh
2007-01-30 11:26 PM
2007-01-31 01:53 PM
2007-01-31 06:16 PM
2007-02-01 11:15 AM
Luis wrote:I still use the C4D CE version (without the plus).
I have the following PLUGINS in the PLUGIN`s FOLDER:
- 50grEy - allows you to simulate a GI solution using a light dome in V6
- bhoudNUT FRESNEL - comes with the software
- BVH - comes with the software
- Maxwell ( I tried to make it work but it´s not for version 6 )
- RES
Each one has an specifc folder in the PLUGIN folder.
The Cinema 4D CE6+ has only the following menu ways for configurations:
- MENU EDIT > PROJECT SETTINGS
- MENU EDIT > GENERAL SETTINGS
I could not find PREFERENCES in the menus. None of the following menu ways has an specific configuration for plugins
People in the tech support only works with the version 8 or later. This what they said as an answer of my last support message. So I think there is no available support for version 6. Maybe I am wrong.
Forgive my grammatical english language errors. In Brazil we speak Portuguese.
THANKS A LOT.
2007-02-01 11:16 AM
2007-02-12 04:49 AM
2007-02-12 10:01 AM
Luis wrote:(Turn of CAPS LOCK, please.)
HY STEFAN
I DID JUST LIKE YOU SAID TO ME AND THEN I COULD SEE THE PLUGINS AT THE MENU LIST BUT THIS LIST WAS ALWAYS GREYED.
I SPENT SOME TIME TRYIND TO UNDERSTAND THE REASONS. I THINK
I GOT PART OF THE ANSWER
THERE PLUGINS THAT BECAME AVAILABLE DEPENDING ON THE KIND OF OBJECT IS SELECTED. I STILL DON´T KNOW EXACTLY WHAT KIND.
OTHERS PLUGINS ARE USED AS A TAG ADDED TO A SELECTED OBJECT. 50gREY IS ONE OF THIS PLUGINS BUT EVERY TIME I TO ADD THIS TAG I GET THE MESSAGE - " NO LIGHT DOME OBJECT FOUND-YOU MUST USE A POLYGON OBJECT AND A VALID NAME"
COULD YOU HELP AGAIN ??
THANKS A LOT.
