Visualization
Photo Renderings don't save an alpha channel
fuzzytnth3
Am I right in saying that when you generate a photo rendering in AC 9 that there isn't an option to save the background as an aplha channel?
This is something Strata 3d CX does which saves a bit of time when montaging into a site photo and I suspect I'm trying to endow AC 9 with abilities it doesn't have as a result of using Strata quite a bit
tia
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Hmm. I think you may have come across a bug.
There is a check mark for both the Internal and LW engines to use alpha channel for transparency for the background image.
But: with the internal engine in 9.0, if I check this box, then my model is not rendered ... I only get the background (and no alpha).
With LW, and this box checked, the result is the same as if the box is unchecked.
Anyone?
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dwight
I notice this, too.
Dwight Atkinson
Same with AC 8.1.
Try AC 6.5 - it worked then...
