2011-06-1406:34 PM - last edited on 2023-05-1103:11 PM by Noemi Balogh
2011-06-1406:34 PM
I often like to create a Presentation Sheet with a project that displays 3D views of the project from all four corners. (and with additions I may also have some views of the Existing)
I create these views using the internal engine and Hidden line mode.
Once the views are saved to the view Map the file size usually increases by 10-40 MB then the views are placed on a master layout page and the file size increases even more. Is there a way to accomplish presenting these views without greatly increasing the file size. These large files seem to end up taking a long time to Autosave (which really cuts into productive time) and saving the file.
What about saving the views as a "3D document".
You can adjust the settings to show just linework and hatching.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
In response to the JPG; I had tried this before but the file was "grainy" and it is not Live, yet could easily be re-created and Auto-linked to the external JPG. I will try again and see if the JPG is better quality.
AS far as the 3D Document. I will have to look into this. I have linked a shaded 3D Document from the Open GL engine to a drawing before. I forget if this was a "live" Document.
How much decrease in size do you get if you save those View without any 3D vectorial hatching?
I am guessing the individual lines in those 3D vectorial hatches are what cause the large size increase.
You may also try publishing those Views as PMKs and placing the PMKs on Layouts.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
