Problem with LightWorks Engine
Greetings ArchiCad gurus.
I would like to ask for your assistance with a small issue. When I try to create a render in the lightworks engine I get wierd pixel anomalies which are, on this picture, most clearly visible on the inside furniture.
If I create a render in the internal engine the it comes out just fine, but I would obviously like to use the the lightworks engine because the renderings are substantialy better. Oh and the same issue appears on other projects aswell
Pardon my lousy english, and thank you for any suggestions
2 Replies 2
Do all your furniture items have the same material?
Why not try rendering only a chair and see what happens. If it renders with same pattern then you need to edit its material settings - "Lightworks Shader Settings" or change materials.
Dwight
With the material showing thru glass like that it is hard to be sure.
Post the sunlight setting and the material setting and i will analyze.
Dwight Atkinson
