Learn more
Problems with Camera an VR Object
Hello!
I have a problems with Camera (Flay- through) and VR Camera!
When I want generate presentation, program shows me next message:
Can't generate movie
Error code - 7003 ()
2 Replies 2
Dwight
That's a "missing driver" error code.
Not that it is always correct.
So now what?
Could be a damaged VR engine - broken driver.
Could be not enough RAM to load the driver....
How much RAM?
What machine? WHEN POSTING A QUESTION ALWAYS GIVE YOUR MACHINE AND SOFTWARE INFO OR SOME BULLY MIGHT KICK YOU OFF THE FORUM.
How many polygons in the model? Will it work with a small test or any model?
Does this happen with PhotoRendering or can it create an OpenGL rendering?
Have you set your light quality outrageously high?
BTW: Only Hannibal Lector does flay-thrus.
Dwight Atkinson
Now i have a description of my machine! It doesn't work in any fotorender
model, But i didn't try an OpenGL rendering.
I thing too, that i don't have enough RAM.
I try VR object last week and it works. Now I just add a mesh and trees, a few cars.
I dodn't now... Maybe I have to upgrade RAM on 1,5 G!
How much light quality is optimal?
Thanks for your answer Dwight!
