Visualization
Problems with neighbouring houses in Twinmotion
DonCad2
I'm having trouble with the existing neighboring houses, which are morphs. When I generate an image with Path Tracer, the morphs look like this:
2 REPLIES 2
derekjackson
If you mean the issue is the stripes, that's a known bug. Try adjusting Shadow Bias or using Depth of Field to eradicate it.
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Earthworm
Your object is probably placed far from the origin in Archicad. Move it closer, create a new export file and re-import. You obvious have to drag your object to the correct location in TM because it's origin has moved but that should prevent those artifacts.
ArchiCAD 27 | Intel Xeon W-2225 - 4.10GHz | 32 GB RAM | GeForce RTX 3080 | Windows 10
Setup info provided by author
