2009-08-06
11:53 PM
2023-05-11
02:37 PM
Noemi Balogh
2009-08-07 12:24 AM
2009-08-07 03:52 AM
another Moderator
2009-08-07 03:08 PM
lec1212 wrote:I thought those were restricted to 3D views? What I am hoping to send out are large colored (by zones) 2D floorplan views with few annotations (room names, etc) for presentation boards. Sounds like this may be something Graphisoft could improve on for further releases if possible. I may add this to the wishlist but will give it until the end of my workday today. For the time being, I will check out those custom actions ejrolon mentioned.
I don't do much of this, but the only way I've gotten a larger file out is in the photo rendering setting.
Document>Creative Imaging>Photo Rendering settings
There is a box in upper right corner to set resolution(dpi).
Then of course do a save as in any of the available file formats.
2009-08-07 03:17 PM
another Moderator
2009-08-07 04:47 PM
ejrolon wrote:Wow. For some reason I was thinking I couldn't insert PDFs into Power Point. Can't remember if previous versions of either PDF or PP prevented that.
- I though you could insert PDF's into PowerPoint presentations, if so the same reasoning for Presentation Boards apply.
