Learn more
Realistic view parameters
Hi all!
Im just aboutto finish my project and need to render a few parts of it.
The project is a house and i need my client get the impression of how spacious it will be. My question is how should i set the parameters of 3d view or camera to get that feeling.
Could anyone share experience?
3 Replies 3
David Maudlin
RoodyHood:
For exterior shots I set the View Cone to 60 degrees, which gives a realistic view angle. For interior shots I set the View Cone to 80 degrees, which is somewhat wide angle, but gives a fuller impression of the space.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for advice, your most welcome. Im just starting to play with it..
Reall human view angle is about 36 degrees.
Wider with women - they don't turn their heads after men so often!
