Reflection in model image rendering
Please see attached image that was rendered in ArchiCAD 14. How do I reduce the reflectivity in all the surfaces?
3 Replies 3
No image
Here is the image
Go to Options> Element Atributes> Materials, make sure the Lightworks Rendering Engine is selected under Create Preview, select relevant material and adjust the Reflectance setting as required.
