Align 3d tecture, Set direction
I am uncertain how to use the set direction tool. When you try to define it graphically, is provides results contrary to any direction you define. Is it the direction line defining the 0? the 90? the up? What is the angle relative to? the project the object?
I will always begin by resetting the the surface, then setting the origin, then setting the material to 0 for some baseline....but it seems so indifferent from and numerical degrees input or graphic vector input.
Any ideas?
0 Replies 0
