Render mesh Enclosure at Arlantis
Hi all ,
I wish to render mesh Enclosure (beside Gable covered roof) at Arlantis, but it's seems like a solid wall with mesh patterns on it!! >_<.....it's render all right at "lightworks" when Alpha Channel of the mesh (PNG file) is on.
In Artlantis, the mesh Alpha Channel is on too~~ Just have no idea why the mesh wall still won't see through.
Have I missing something??
Please help!!!
Thanks
Star
14 Replies 14
then~>>
1. add "png" file Metal mesh from my library hard drive in my computer.
2. and click ok, as you can see an image attached on to the "metal mesh" on material list.
3. click on "repeat texture vertical" and "repeat texutre horizontal"
cont.....
and next~>>
1. click on "use alpha channel"
please ignore no. 2 on the image.
and here you can see through mesh enclousure~~!!!
I think you went about it the wrong way.
Use dwights method, but, Alt-Click the color in the texture you want to make transparent.
See attached file.
I hope this helps.
Justin
hi Justin,
Thank you for your hint,
in fact, I've actually tried to check that box, but not working in both Png. and jpeg file~!! But me never tried Alt-click on texture mapping, I will try that sometimes today.
Cheers
Star
Dwight
Uncheck the other box first.
Dwight Atkinson
