2017-06-02
		09:17 PM
		2023-05-11
		11:56 AM
			Noemi Balogh
2017-06-03 02:51 PM
2017-06-05 04:18 PM
2017-06-05 04:49 PM
2017-06-06 11:22 AM
2017-11-17 02:14 PM
Erwin wrote:
Nothing much to add that Mikas didn't already write, apart from: the preset scenes are 'bad'. Medium or especially Final, are rediculously high render time compaired to Fast.
I generally start out with Fast Physical preset and start tweaking it.
Swap in a better looking sky preset in the environment tab, make sure that ArchiCAD sun is still ticked there.
Switch to Detailed Settings.
If I have any lamps added to the model, make sure they are on as well in the Light Adjustments.
In Environment > Physical Sky > Clouds, I turn off the shadow casting from clouds. Doesn't look good and adds render time.
No Effects are on.
Global Illumination, go to the first tab and use either Exterior - Preview or Interior - Preview depending on exterior or interior scene.
Physical Renderer > Physical Camera. Set up the iso, shutter etc as I would an actually photo camera for interior or exterior scene to make sure the light balance is ok.
And now the thing that does need to be upped, in my opinion, for better than 'fast' render. Options > General Options > Ray Threshold 0 (for awesome reflections), Ray depth I would go with 11 or 12 as a safe number, same for Reclection depth.
If you want to add in a custom sky in photoshop later, check the generate alpha mask button here as well.
Save this as a preset scene, so you can use it again later and export and import it to other projects.
For run of the mill residential projects, this keeps my renders at max 30 minutes for exterior and max 60 minutes for a detailed interior.
But, yeah, get 16 GB of RAM and your i5 will not do what my (oooooold!!) Xeon does, sadly.
				2018-06-20 08:33 PM
Erwin wrote:I'm not seeing a Fast Physical preset available.
2018-06-21 10:19 AM
