‎2006-07-14
08:19 PM
‎2023-05-11
12:32 PM
Noemi Balogh
‎2006-07-15 07:39 AM
‎2006-07-17 02:46 PM
‎2006-07-18 02:40 AM
kevin wrote:I just can't replicate that one. Sorry! Maybe someone else will comment?
I had been using both, predefined 3D views and just going form 2d to 3d with shortcuts. And I know that those setting sare saved with the views but it seems like in AC9 if you weren't using a 3D view but activated the 3d window the settings would be whatever they were the last time you did it. Now it seems like it will always revert back to the setting of the last 3d view that was saved. When I saved off a new view with the new settings it will now always revert back to that one.
kevin wrote:Now
Another thing that seems to have changed is that when you have a 3d view saved with a marqueed area, when you go back to 2d the marquee does not show up in plan. It used to be, if I recall, that when you switched to a 3D view with a marqueed area when you switched back to plan the marquee would be there.
These all fall under the it's jsut a wee bit different category of things that drive you nuts til you figure them out.
