2018-06-26
11:08 AM
- last edited on
2023-05-11
11:54 AM
by
Noemi Balogh
Solved! Go to Solution.
2018-06-28 01:57 PM
t_and wrote:Screen shot attached, thanks for adding the signature.
Thank you very much for your help but I don't find the option you say and can't find a post talking exactly about this in the forum. If you ever have 2 min would you be able to show me it on a screenshot? Thanks a lot
PS: Signature optimised, thanks😉
2018-06-26 03:11 PM
t_and wrote:Yes, place a marquee (flat option) and select "Render Marquee Region" from the PhotoRendering Settings palette.
1- Is it possible to render just a corner/small part of a picture so I don't have to re-render an entire picture if I just change a small detail?
2018-06-28 09:34 AM
2018-06-28 09:45 AM
2018-06-28 11:11 AM
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2018-06-28 11:22 AM
Lingwisyer wrote:That is correct.
I've been unable to "update" a past render with the marquee of which I think the OP is wanting. I just end up with the marquee'd area on a black background? Merging the old and new render is then required.
Ling.
2018-06-28 12:08 PM
2018-06-28 01:57 PM
2018-06-29 02:02 PM
David wrote:Thanks to you for your time
David
2018-06-29 03:28 PM
