Visualization
Render your model with built-in or 3rd-party solutions
Rendering problems! Won`t stop calculating!
Helo!
Please help! I am a student working on my diploma!
When i try to render pictures, the renders won't stop calculating. When its 100% calculated it just starts over again. And like that it keeps on going for hours. I am rendering in a A3 format and with 300 pixels. Its not a complicated picture that i am trying to render so i dont understand the problem, when this haven't happened before. I am using ArchiCad 20.
Please help
2 REPLIES 2
David Maudlin
Evelineevis:
Which photo rendering scene are you using? One item that takes a lot of time is Grass. In the PhotoRendering Settings, check the Detailed Settings box, then go to Options > Grass and make sure it is not checked.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
mikas
You might have run out of memory. I would say your picture resolution is quite high, your rendering is ending up to be a 17,4 million pixel picture. That's more than a 4K or even a 5K resolution. Maybe you can make that 150 pixels/inch. I don't know what is your desired final output size for your rendered picture, but if it is A3, I would say 150 dpi resolution can be a really good looking print - depending on the printer of course.
So first you might want to take resolution down, and as David allready suggested, look at the settings more closely. You might not need the best settings for everything. I have found the "medium" setting for rendering quality and lights are often quite enough, also the "low" -settings are enough while you are testing the renders.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
