Visualization
Renderiong Error Issue
Can you let me know what i can do to not get that error.
followings are few renderings that i have done of the partial buildings using Marquee Tool.
But when i try to do full building sketches and rendering with a surrounding buildings it just gets stuck. Progress message tells me that there is only a couple of minutes remaining but then it gets stuck.
Potentially low memory?
Potentially to high of resolution?
Please can you suggest what i can do to make it work.
Thank you.
Computer specs: P4 2.40GHz and 1GB of RAM
4 REPLIES 4
Djordje
http://archicad-talk.graphisoft.com/viewtopic.php?p=37423#37423
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I am having problem with 3d image when i show all the floors in 3D window i do not get anything. Just stays there, looks like computer went for lunch.
And if I click on ArchiCAD window everything becomes white.
What to do
Please Help
Than you
I have the same problem - but only in 3D with lot of GDL central 3d trees ... I´m getting LW rendering with no sun shadows. I´d blame the trees - sometimes I don´t even get the 3d view, especially with the bushes.
I use P4 3GHz, 2Gb RAM, WIN 2K
So what do you thing could be a solution to our problem
