2015-11-2302:01 PM - last edited on 2023-05-1112:50 PM by Noemi Balogh
2015-11-2302:01 PM
Hello.
I am having trouble with reversing my image texture on my bent wall. It is showing the wrong way/mirrored.
It is fine on a straight wall, but when I bend the wall with a curved angle, it gets reversed.
Does anyone know how to fix it?
I have tried mirroring it on the x and y axis in the cinema engine, and setting diffrents directions in the internal engine.. None of this does it.
If nothing else helps you can simply duplicate the image used for the texture in an image editing application, then mirror it and use that image on the Wall.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
Thank you!
So easy solution, but my mind is not working properly due to exam stress.
I didn´t find any solution in Archicad though, but mirroring it in Photoshop should be no problem.
