Visualization
Scaled Image background
Whenever i try to create a rendering with the background set with scaled image. It doesn't work. The background is renderer as black. Am i the only one with this problem?
is render background with internal engine on?
It's rendered with the lightworks engine. With all the settings that you'd normally do to render the best pictures. When i set the background as a fixed picture it works fine, but this means that i have to rescale the picture myself, load it up again, and render.
