Scaled Image background
Whenever i try to create a rendering with the background set with scaled image. It doesn't work. The background is renderer as black. Am i the only one with this problem?
2 Replies 2
is render background with internal engine on?
It's rendered with the lightworks engine. With all the settings that you'd normally do to render the best pictures. When i set the background as a fixed picture it works fine, but this means that i have to rescale the picture myself, load it up again, and render.
