We value your input!
Visualization
Screen Movie recording
TomWaltz
Can anyone recommend a good software for the Mac that could be used to record screen activity, say for example recording Archicad methods or working?
Tom Waltz
9 REPLIES 9
Gerald Hoffman
Hi Tom,
You might want to try Camtasia Studio by Techsmith. They put out a program called Snagit which I find very good and you can download a trial copy.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Eduardo Rolon
Snapz Pro from Ambrosia is the best one in my opinion
www.ambrosiasw.com/utilities/snapzprox/
and the one I use regularly
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
I haven't used either of these, but they were recommended on lifehacker.com (usually pretty good with software tips):
Macromedia/Adobe Captivate: http://www.adobe.com/products/captivate/
Ambrosia: http://www.ambrosiasw.com/utilities/snapzprox/
Gerald- I think Camstudio/SnagIt are windows only?
Gerald Hoffman
You are right about Windoz only.
I had done a quick check of the site and saw OSX in the download section but on rechecking found out it was just for a Codec not the programs.
Gerald Hoffman
TomWaltz
It appears Adobe Captivate is Windows only as well 😞
Tom Waltz
TomWaltz
I must agree. Snapz Pro works pretty well. With H.264 compression, the files are even a manageable size.
Tom Waltz
Eduardo Rolon
The trick I have found out (Based on the Manual) is that when you finish recording the screen capture, the compression setting should be Animation to save the Movie from Snapz and then into Final Cut for Post.
AC27 US/INT -> AC08
another Moderator
TomWaltz
I did something similar. I used those settings then used QuickTime Pro to compress it.
Knowing me, I'll be putting it in Final Cut soon enough and adding wipes, fades, special effects, and it will be "Archicad Takes Manhattan."
Tom Waltz
Thomas Holm
Make it downloadable, Tom!
