Visualization
Screen Porch Surface
scsp
How do I make a surface like in the case of a screened porch/pool cage view as transparent/screen in a 3D view and/or 3D document?
I have searched and can't find anything that works for me when I implement it. I am using Archicad 22.
Thanks so much,
SCSP
To create a semi-transparent surface you can start by making a new surface or just duplicate an already transparent surface like glass..
Then add a vectorial hatch - maybe a 25% fill, and set it to use a very light coloured pen.
The transparency level of the surface will affect the 3D view.
The fill and the pen colour will affect what you see in elevations.
Make sure transparency is turned on in elevation settings and 3D style.
5 REPLIES 5
Podolsky
Ace
Use curtain wall, man.
Podolsky
Ace
By the way, in UK it called 'conservatory'.
scsp
Thanks SO much!
And, here are some old threads with some illustrations... by using the Search > Advanced Search for "screened porch":
https://archicad-talk.graphisoft.com/viewtopic.php?p=219118#p219099
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=51563
