Setting Resolution in 3D window to 300 dpi in 8.5x11
As I understand the default resolution of the 3D window (OpenGL & Internal Engine) is set to 72 dpi. Can one set Resolution in 3D window to 300 dpi to achieve 8.5"x11" window area. I am trying to export the image to Piranesi to achieve sketch/water color rendering.
Thanks,
Joseph
11 Replies 11
Djordje
Joseph wrote:
Djordje wrote:
As the Piranesi export is a rendering, you just specify the pixel size.
Do I need to only set the Size in Photorendering Settings of LightWorks and then Save As from 3D window
OR
I have to first do PhotoRendering Projection and only then go to 3D window and Save As.
Thanks,
Joseph
Just set the size in Photorendering settings
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks a Million
