2010-04-3003:56 PM - last edited on 2023-05-1112:51 PM by Noemi Balogh
Setting Texture Origin on Complex Walls
2010-04-3003:56 PM
I want to set an origin for my texture on one surface of a complex wall, but using the 'Define Origin' tool seems to affect all materials involved in the complex wall (ie I set my cladding material origin, and it moves the brick material further down the wall too)- is there a way to set their respective origins independently?
Derek, I think you will have to use separate complex profiles... The reason being is: the Set material origin and direction tool affects the entire entity -wall -beam or column.
Regards
Nando Mogollon Director @ BuilDigital [email protected] Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes) More and more... IFC.js, IFCOpenShell All things Solibri and BIMCollab
