Sketch Mode Prints Interior
In Archicad 14, I'm using Sketch mode to render the Exterior of the house, but the interior is showing up on the sketch as well. This used to not do that in Archad 8,9,11 & 13. How do I keep the Interior of the building from showing up in a Sketch rendering in 14?
Thanks.
2 Replies 2
Under the "3D Window Settings" make sure the "Transparency in Shading" setting is set to off.
Thank you. That worked.
