Super light lines in printed elevations
Everything looks fine as far as line weights until I print. The lines that fall in the immediate are dark enough, but anything behind is almost invisible.
Any suggestions?
I am using Archicad 20. The graphic overrides are set with zone fills: empty and cover fills: white. I don't have any other overrides. Everything is set as new construction too.
Erwin Edel
Could be marked distant area that is using different pens.
You can either set one pen for this or let ArchiCAD make them 'lighter', which assigns (in my opinion) 'random' other pens. For my penset I have figured out which pens gets changed to which and adjust the pen weights and colour accordingly.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
