‎2019-04-09
03:20 AM
‎2023-05-26
02:55 PM
Rubia Torres
‎2019-04-09 03:51 AM
‎2019-04-09 04:06 AM
Barry wrote:I considered that but this is a completely fresh install of ArchiCAD as of today.
I would be guessing that someone has edited the texture on the second computer.
Track down the 'Curtain White-opt GS.png' file on both computers and have a look at them in an image viewer/editor.
I would be guessing that one has been 'photoshopped' so it is blue.
The Cinerender surface is probably fine as it is probably not using that same png file for the texture.
‎2019-04-09 04:45 AM
‎2019-04-09 06:24 AM
Barry wrote:I checked and the other two files related to the same curtain texture (I think bump and something else) were all blue tinted, however other textures if I kept going through them all seemed fine.
I am now wondering if maybe a texture has been saved in the embedded library and maybe that is being used?
If you change that texture shown in you image for another one - is that tinted blue as well?
‎2019-04-09 08:01 AM
‎2019-04-10 12:37 AM
Barry wrote:The files are blue yeah
So when you go to load a new texture file, are they blue in the preview there as well?
If they are blue but other files are not then I would say that something is wrong with that texture file - why I don't know.
Maybe copy the surface catalogue file from the machine that is OK to you new machine and then re-load the library in Archicad.
‎2019-04-10 03:50 AM
‎2019-04-11 01:04 AM
Barry wrote:I realised my response before was a bit vague. It was just the curtain textures and no others I could see were changed in colour.
If only just a few of the texture files are blue then swapping the LCF file should fix it I would think.
But if all of the texture files are blue (no matter which one you pick), I would say there is something else going on and swapping the file probably won't help.
What the problem is then I couldn't say.
Maybe a video card/driver issue - but then why does it affect just the curtains and not the cabinets in your image?
Are all job files on your machine the same or is it just this one?
If just that one file and it is opened on another machine is OK?
