‎2005-02-26
10:06 PM
‎2023-05-11
02:25 PM
Noemi Balogh
‎2005-04-08 04:51 PM
‎2005-04-08 07:01 PM
‎2005-04-10 01:37 AM
‎2005-04-10 01:39 AM
‎2005-04-10 02:20 AM
‎2005-04-11 10:12 AM
Steve wrote:Not so shocking really as your images appear to be raytraced rather than radiosity renderings. There is quite a difference between the two, if you compare for example the shadows created by the glazing on the floor in your image they are very sharp which is fine for a sunny day in California not really what you get in Edinburgh even at the height of summer
I am in shock at the huge render times it is taking others to generate a good picture.
‎2005-04-11 10:29 AM
Burginger wrote:Adobe After Effects. Or Autodesk Combustion.
Here is Justin's image showing the layer control you can have with each render. I think you can do this type of control with animations too. It requires some Adobe application, can't think of the name right now.
‎2005-04-11 11:08 AM
‎2005-04-11 11:32 AM
‎2005-04-11 11:35 AM
