‎2005-02-26
10:06 PM
‎2023-05-11
02:25 PM
Noemi Balogh
‎2005-04-11 02:53 PM
fuzzytnth3 wrote:I have used the older CE6+ for this image.
Thanks for the link, I will take a look at that. I actually have an older version of Cinema CE6+ or something like that.
I got a bit annoyed with it (most likely due to my incompentance) as I use a two monitor setup and found the Cinema interface a bit of a swine to get it configured the way I wanted it. Also I found defining materials and the like not as straight forward as Strata or ArchiCAD for that matter.
I should give it another try and if I remember right, somewhere on the forum Mark B posted a tutorial for a workflow from AC to Cinema which I obviously should give a go to do Cinema justice.
Thanks again
‎2005-04-11 05:05 PM
"fuzzytnth3The Artlantis render certainly looks very harsh to me. It sounds like Artlantis 5 may well address these issues but at the moment it certainly seems to be lagging behind the current market.[/quote wrote:
Not for long.
Check this out.
http://homepage.mac.com/nicolasrivera/My%20Artlantis%20R/index.html
‎2005-04-11 06:12 PM
‎2005-04-13 04:18 PM
You must think about lighting the scene separately from populating the scene with lamps and light sources and expecting these "real" things to model the light.
‎2005-04-13 04:43 PM
‎2005-04-13 04:51 PM
‎2005-04-13 04:55 PM
‎2005-04-13 05:01 PM
kevin wrote:
"Note: all shaders are described in detail in help files located in the Library Examples/Documentation/LightWorksIntegration folder of your ArchiCAD 9 folder"
I do not have this folder, and we did a full install. Anyone have this? And what elese am I missing as far as documentation?
‎2005-04-13 07:43 PM
fuzzytnth3 wrote:Usable for what fuzzy? I suppose if you had it printed it on a nice 3-ply quilted tissue paper it could be used for something.
Here's an AC+LW render, took 127 seconds. Fakosity shadows and the lighting to the ceiling is a bit obvious but useable
‎2005-04-13 08:22 PM
Steve wrote:fuzzytnth3 wrote:Usable for what fuzzy? I suppose if you had it printed it on a nice 3-ply quilted tissue paper it could be used for something.
Here's an AC+LW render, took 127 seconds. Fakosity shadows and the lighting to the ceiling is a bit obvious but useable![]()
...oh come on, thats got to make you laugh!
Steve wrote:I agree, that's the point I'm trying to get to. I do think the way my straight ArchiCAD LW render is looking isn't bad except for the reflected light at the junction of the ceiling and walls. I have attached another rendering but this time without the "fill" ceiling light. It appears that the white material for the walls has perhaps got a bit to much "reflectivity" in it which is making it look a bit artifical.
Seriously though, I would like to see this test model rendered as well as it can be done with ArchiCAD Lightworks only. I want to see what the best it can do is. So far all I have seen is results from a bunch of people struggling to figure out how to generate even a "usable" rendering. If the best it can do is nice, I will learn how to use it and compare what the best I can do with it is vs. the best I can do with Art*lantis. Then I can make a decision about what is best for me.
If I can't be proud to sell it to my clients, it's not usable.
There are some (no doubt) who can do a better job with one than the other.
There must be someone out there who is willing to show us how well ArchiCAD Lightworks can render this scene.
The reason I want to see this scene is because I have this model. If you want to use a different model, fine, but post it too so we can all use the same model for a good test.
