Visualization
Textures in 3D
I only occasionally use the built in rendering engines. I used the Design/Align 3d Texture/Set origin command to align the textures of the siding in this project. The texture comes out right in the Elevations, and the 3D Photorendering using the Sketch engine, but the textures are misaligned when using the Internal engine.
Attached are the Sketch and Internal engine renderings. What could be going wrong?
1 REPLY 1
In your material settings where you choose the texture, there is an option for 'Random Origin'.
I am guessing this may be ticked.
