Visualization
Tips Alpha Channel & Texture Correction in LW
My hope it can useful for all
Apology, if related this topic already posted before
3D Window Preview :
Render with Lightwork :
Tips in Photoshop & Lightwork Rendering:
If those related links get broken, just download content at the next post .
9 REPLIES 9
Link
That's a pretty decent tip!
Not sure why you were banned for it. Hopefully it was a mistake that will be reversed.
Link.
Thank You Link,
I believe this mistake (Banned account) already corrected.
have a good day!
Dwight
Easy to fix when you know the right people.
Dwight Atkinson
Due Uploaded server often unable to present this threat,
I decided to re-post this topic.
Preview how it's used:
Photoshop Section tips: Creating Alpha Channel (Part 1)
Tips Texture Correction in Lightwork Rendering: (St. Layout Is the Answer) AC9 User
Users of Archicad 10 should note that when "Matching Internal Engine," to transfer texture map information from the Internal Engine to the LightWorks Engine, that the transfer bug inverting the texture map in Archicad 9 has been fixed.(Dwight Atkinson)
Dwight
Please let me add one modification to this list of instructions:
The ST layout instructions will now result in an inverted image.
Dwight Atkinson
Thank you for your Information Dwight!
I didn't realize that was a bug! (till u explained it)
yes, I'm using AC9 to work with it!
Dwight, Final released of AC9 still appear this bug?
Cheers!
Dwight
you would need to answer that for yourself.
I am always so far ahead of the curve......
Dwight Atkinson
