Visualization
Top Ten LightWorks Problems
Dwight
Please help me make a list of your top ten LightWorks problems. Or twenty. We will see how it goes.
Dwight Atkinson
16 REPLIES 16
Ben Odonnell
That there is no radiosity module.
That none of the "normal ArchiCAD" lights work as the 3 other Lightworks lights work.
That you don't get real time feedback on materials(Yea I know that you get direct feed back in the preview window but may be make it a tad bigger), they don't show up when OpenGL is used. I know that this is also hardware driven, but hey you can always whish for it.
Well that's it for now.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Get your BIM objects from bimobject.com
Rakela Raul
no book to learn from
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Dwight
Not to provide a defense, are you aware that the lights in "General Light Sources" and many of the lamps themselves are updated to cast soft shadows? The falloff controls are quite sensitive....
Dwight Atkinson
Dwight
I can fix that, Mr. Early Adopter.
Anything else?
Dwight Atkinson
TDabney
I haven't spent much time rendering w/the Lightworks engine, and I know this has ben talked about before, but - the material editors and basic controls are a little on the cumbersome side. It's pretty tedious to run test renders w/different materials and settings. Not the best for efficient work.
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
Some LW complaints/problems in no particular order:
1. That GS put some of the usage documentation (and GDL documentation) in the developer libraries (free download – but not included in the distribution) rather than in the help files and GDL manual. Even that documentation doesn’t cover all user controls / parameters in all LW-related dialogs, but it helps the GDL developer. GDL coders will want to get the Basic Library files from
http://www.graphisoft.com/support/developer/documentation/index.html
2. That the LW material preview in the archive loading dialog is so small as to be meaningless; you have to select the material, then look at it in the main dialog (or apply to a surface and render). Then when you go back to the archive, you have to find your place once again, as it doesn’t remember where the shader came from.
3. Similar to the last one, I would like an option for a cube rather than the sphere in the Material Settings dialog, since I almost never apply materials/shaders to spheres, and the distortion makes it difficult to judge the appropriateness of settings, for example, for a shader-defined wood or stone. The effects of grain size aren’t seen until the material is applied and rendered … time consuming. Then consider reflectance, transparency, displacement etc … Really need a quick-render of just a cube or sphere (at a known scale) that is large enough to judge the result.
4. As Tom Dabney said, the material editor controls are quite cumbersome. I never want to hide controls, and am tired of clearing the checkbox for ā€œShow Essential Onlyā€ each time I go into the material editor.
5. I want a way to easily make sure the size/aspect of my texture image matches that of my mask and/or bump images. (I rarely use different pixel-dimensioned images for the different functions. Give us a ā€˜lock’ button so we can use different sizes when needed, but otherwise keep things in synch.)
6. There is a ā€˜match to internal engine’ button, that is useful. But, once you start really working in LW, you want the reverse … an OpenGL/Internal ā€œmatch as close as you can to LWā€.
7. LW window light behavior is frustrating: as you vary the intensity, the number of lights changes, but there is another parameter that changes the number of lights too. I’ll probably just reprogram this object myself, as I’d rather pick my light resolution and then adjust the intensity without altering the light count.
8. No radiosity, as mentioned by Ben Odonnell
9. Can only use some archives … AC LW is not certified for archive use. We should be able to open, for example, the Benjamin Moore paint archives.
10. Light behavior sometimes gives artifacts: I have seen mysterious dots reflected in glass from a window light, and strange waving patterns on walls and ceilings, like the guy with the plaster was bouncing up and down with his trowel, drunk, or both.
11. There is no way to visually align LW textures in 3D since the 3D OpenGL window uses the internal textures. If you ā€˜match to internal’ this is not a problem. But, if you use a LW shader, you can only guess (AFAIK – perhaps a tip in Dwight’s book) to get the alignment where you want. Then render, and re-render. Very time consuming.
12. Light intensities combine in what seems to me to be an unpredictable way, resulting in extra renderings and time. For example, with the sky object and sun object present for an exterior rendering, it is easy to overexpose surfaces, such as the ground/lawn. So far, it has just been trial and error for me to find settings that are satisfactory and expose things adequately.
13. Soft shadows just don’t work AFAIK. If you adjust shadow softness for the sun in the LW Environment of the Photorendering Settings, there is no meaningful change. Nothing produces shadows similar to Art*lantis, much less C4D. I just modified the Sun object which calls for hard shadows in its 3D script, to instead call for soft shadows and there was no effect. My guess is there is some bug in the integration of LW in AC 9.
14. The material selection pop-ups don’t have any visual clue (icon) to let you know which materials have LW definitions that are other-than ā€˜match to internal engine’.
In spite of all of this ... I use LW as my engine of choice with AC.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dwight
1: my book will be condensing the cumbersome geeky documentation ito useful phrases
2: yup.
3: yup.
4: I heard tha this is the most hated non-feature
5:yup
6: yup
7: should always have this low anyways.
8: true
9: unreliable response form GS on this - "ifn'n it don't work, don't try to use it!"
10: less liquor required - reflection very bad when close to parallel....
11: pure shaders still start from an origin but where is it??
12: every rendering takes at least two tries [ruleofthumb] and you need a quarter stick of dynamite for every 4" of trunk diameter.
13: I have established a compromise on this and a fix may arrive fro HQ.
14: yup
Thanks.
Now, how about some artistic challenges users face?
Dwight Atkinson
Rob
1.missing implementation of ALL LW light source types such as a linear light etc.
2.Light lib parts that allow precise light definition by lumen/lux values or at least bulb type/wattage definitions (like 100W incandescent, MH, Halogen etc) for beginners.
::rk
Oh yeah:
15. Default color of sun object in library is blue...rather than yellow-ish.
Artistic problems: perhaps tomorrow. šŸ˜‰
