Transparancy
Hello everybody, im doing a building that has many windows but when i go to the 3d view it wont show its just a grey surface, does anybody knows how to do this?
1 Reply 1
Under "Image - 3D Window Settings" set the "Mode" to "Shading" and make sure under effects that the "Transparency in Shading" is On. This should give you the transparent veiw of the glass.
If the glass still shows, check to see the material assigned to the widows is transparent.
Good luck,
