Transparent walls
Hello
I'm a drafter-student and are learning ArchiCAD 7.0
Recently I have made some houses, and having problems with the walls.
When I see it from straight front, the shadows seems to stop in inner-walls, and not outer walls like it should do. And same otherwise with lamps and light from inside, have seen it making light on the gras outside the building.
Anyone have some idea what I'm doing wrong?
Or maybe it is a bug that have ben fixed by producer, but not been updated in school?
I have no idea whats happening, ether does the teacher.... as I'm the only one that gets that in class
Thanks in advance
Oyvind
6 Replies 6
Djordje
Can you please post a rendering? That would explain much, much more ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello
Sorry I haven't done anything about this lately, have been some busy.
I will add some pictures to maybe able to explain what the probem is.
And it seems like the wall are transparent somehow...
Have a nice day 😃
Here are the shadow all over the left wall, while the center wall are futher in.
Here the shadow are different on same wall.
And another image where you can see light-circle from spotlights from kitchen inside.
vfrontiers
Turn SHADOW CASTING FROM LIGHT SOURCES ---- ON....
Duane
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
