Visualization
Trouble with sun direction if window lite...
If I use window lite and sun lite and change sun direction, it doesn't work.
Of course I shutt off manual sun direction from sun- and window lite.
Dwight
rebuild 3D + 2D window before re-rendering. Watch sun direction swing.
Dwight Atkinson
Thanks
It has confused me because sun direction of sun lite and window lite shows correctly, but not in photopicture...
Dwight
It is possible to have the plan look correct, but the rendering not correct, because unless the 3D window is rebuilt, the 3D file that is used in photorendering is the last one seen, so always rebuild the 3D window when you make a change, or enable this option in the preferences.
Dwight Atkinson
