Visualization
Twinmotion / clay / animation
Foti
Hello
When you set up an image, you can apply a clay render to that image.
Can that same effect be applied to a video, I want to export a video scene but with the a simple all white palette.
Thanks
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
Foti
never mind, found it. sorry
Foti B.
AC25
Foti
Foti B.
AC25
Twinmotion questions should really be asked on the Twinmotion forum.
I am not saying you won't get an answer here, but only a low percentage of members here may use Twinmotion.
Whereas on the Twinmotion forum, they all use it.
Sorry Barry, didn't know that one existed nor checked, my fault. It was easy fix, its part of the options for the video you make. simple click.
Foti B.
AC25
