ā2022-11-07 04:22 AM
Hello
When you set up an image, you can apply a clay render to that image.
Can that same effect be applied to a video, I want to export a video scene but with the a simple all white palette.
Thanks
Solved! Go to Solution.
ā2022-11-07 04:24 AM
never mind, found it. sorry
ā2022-11-07 04:27 AM
Twinmotion questions should really be asked on the Twinmotion forum.
I am not saying you won't get an answer here, but only a low percentage of members here may use Twinmotion.
Whereas on the Twinmotion forum, they all use it.
ā2022-11-07 04:31 AM
Sorry Barry, didn't know that one existed nor checked, my fault. It was easy fix, its part of the options for the video you make. simple click.
